MCE remote with VLC plugin
Tetsujin
Post by Tetsujin »
I am a newbie and I am willing to learn to code only if someone holds my family hostage.
Is using Event Ghost with the MCE plugin even possible with the VLC plugin?
Currently I can see the Remote commands in the Eventghost window.
Everything looks perfect. I can only get play and stop to work correctly.
I am assuming this is a problem with the VLC plugin.
I am using the MCE remote because it was really cheap and it fit.
Re: MCE remote with VLC plugin
Tetsujin wrote: Is using Event Ghost with the MCE plugin even possible with the VLC plugin?
It sure is. Got the latest vlc plugin?
Tetsujin
Post by Tetsujin »
The Link on the User Contributed Configs page gives me:
This site canÔÇÖt be reached
eventghost.bizÔÇÖs server DNS address could not be found.
ERR_NAME_NOT_RESOLVED
The Version I am using is dated May 2011.
Is there another place to download it?
Tetsujin
Post by Tetsujin »
I am using Eventghost r1722
Windows 10
HP MCE remote.
I see the events showing up in the Eventghost window But VLC does not respond.
ports in VLC and Eventghost both 8080
How do I troubleshoot this problem?
Tetsujin wrote:I see the events showing up in the Eventghost window But VLC does not respond.
It is unnecessary to create new threads.
Why do you use port 8080? This is typically used to HTML. This may interfere somehow.
Have you read this post?
